smoke coming from bottom of engine
Old May 13, 2012 | 10:07 PM
Wayne350's Avatar
Default smoke coming from bottom of engine
1991 camaro carbed 350. Recently got the oil changed. Noticed what appears to be a faint blue smoke coming from the bottom of the motor. Took the oil cap off and it comes out of there as well. Checked to see if oil filter was loose or bad and even replaced it and it still shows smoke. Any help would be greatly appreciated. Thanks.
Ps. Car does not overheat.
Old May 13, 2012 | 10:09 PM
MKCoconuts's Avatar
Does the smoke blue smoke come out of the exhaust as well? Sounds like you're burning oil.
Old May 13, 2012 | 10:15 PM
Wayne350's Avatar
It.does when I first try and start it but other than that there's really no smoke.
Old May 13, 2012 | 11:25 PM
Did you look under the car while it's running and see where the smoke was coming from? Since it's right after an oil change, it could be from oil that ran down onto the crossover pipe from when the old oil filter was removed. But that should burn off in a short amount of time.
Old May 14, 2012 | 08:17 AM
torque_is_good's Avatar
do you hear a tick tick tick as the engine is running? If so, you probably have an exhaust leak and the exhaust from the tired engine is making its way out there as well as from the tail pipe
just keep a quart or 2 of oil with you and add as needed
Old May 14, 2012 | 10:03 PM
camaroxguy's Avatar
Yeah camaro69 is right, a small amount of oil could burn up a bit. Hopefully it's just that burning oil like crazy sucks. My '83 has whitish maybe blue smoke from the exhaust on start up do you guys think that it's just burning oil or something else?
Old May 15, 2012 | 05:06 PM
microkid's Avatar
March 2011 ROTM
Technical User
could also be an oil leak dripping. valve covers and oil pans are good for dripping onto the exhaust, and if the splash shield isnt on the trans, a rear main seal or trans input seal can sling oil onto the exhaust
Old Jun 4, 2012 | 10:37 AM
mezzyshredder's Avatar
Banned
I'm curious to know the final result. Please let us know. Thanks!
350ci-chev-newb
Oct 23, 2012 08:32 PM
Wayne350
Jun 16, 2012 10:23 PM
shai one
Jan 9, 2012 10:48 PM
RFxCamaro
Feb 20, 2009 05:21 AM
KuwaitCamaroSS
Nov 23, 2008 09:11 PM
