Seatbealt light and buzzer
Old May 23, 2006 | 05:15 AM
Guru's Avatar
Default Seatbealt light and buzzer
Hey guys new to the forum here have a couple problems with my 92 camaro I'm hoping you guys can help me out with... I just noticed the other day that my seat belt light in the dash is staying on whether the front seat belts are hooked or not, also is there a wire for the buzzer running into the bottom seat belt mount on the drivers side? When I take my belt off with the car running the buzzer will come on and off while I move my seat belt. My last question is does anyone know where I can get a full replacement for the hatch pull down motor junk yards around here are not an option as they never seem to have any camaro's (which I guess in a way is a good thing) Any help I could get would be appreciated Thanks you guys
Old May 23, 2006 | 08:32 AM
MoreLikePALcohol's Avatar
Default RE: Seatbealt light and buzzer
hey...the seatbelt thing just sounds like a loose or shotty wire...take apart the piece where the seat belt plugs into and see if it looks sketchy....and check here for a new motor for your hatch...thats just the motor...brand new for a hundred bucks, or here for a used one, looks more complete with the wiring and housing....its one seventy five with a seventy five dollar corecharge, so they both come out the same..hope that helps...later man good luck
Titan85
Oct 30, 2013 10:08 PM
78 on my plate
Sep 12, 2012 10:29 AM
test_tube_tony
Nov 29, 2009 02:53 PM
glsidaho
70-81 V8 Tech
Sep 9, 2009 08:42 AM
microkid
Jan 18, 2007 12:11 AM
