where is the buzzer?
Old Jan 4, 2007 | 11:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default where is the buzzer?
i want to cut the wire to it. if i have my dash lights on, the buzzer stays on because of a bad circuit, but i need the lights to see my speedo, climate control, and shifter.
Old Jan 5, 2007 | 12:31 AM
MadMikeZ28's Avatar
Default RE: where is the buzzer?
You should not need to cut wires. There is a box you can pull out. I think it is on the right side of the column. way up there. Just follow the noise.
Old Jan 6, 2007 | 08:09 PM
microkid's Avatar
March 2011 ROTM
Technical User
i had no luck in finding it with the gauges removed and the bottom taken off.
Old Jan 6, 2007 | 11:05 PM
MadMikeZ28's Avatar
Did you get in the car upside down so your head was on the brake pedal and look up under the dash?
Old Jan 7, 2007 | 01:37 AM
Mike,
You have to stop making people work so hard. LOL
Old Jan 7, 2007 | 02:31 AM
MadMikeZ28's Avatar
LOL
I'm a baaaad boy![&o]
Old Jan 7, 2007 | 08:11 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, i was all up in there, and a bolt for the steering column was in my non-hearing ear, and i still couldnt locate it. moved things as well while i was looking for it
Old Jan 12, 2007 | 07:47 PM
microkid's Avatar
March 2011 ROTM
Technical User
still no luck on finding it. is there a wire i can tape into for a feed to run the wires? i really would like to know what gear im in, my speed, and sometimes the heater controls when im driving at night
Old Jan 13, 2007 | 12:12 AM
MadMikeZ28's Avatar
You cant cut the wire to it because it splits from the headlight switch and goes to other lights as well as the buzzer. I will see if I can take a pic of mine and show you the location.
Old Jan 13, 2007 | 12:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
a pic would be appreciated. what if i cut both wires and just hooked them together completing the circuit without the buzzer?
