RPM GAge!!!
Old Sep 6, 2007 | 07:16 PM
  #21
MadMikeZ28's Avatar
Default RE: RPM GAge!!!
At least they are more common and interchangable over the year compared to fooords. Those jackasses at foord!
Old Sep 6, 2007 | 08:19 PM
  #22
350rs's Avatar
March 2008 ROTM
lol, i agree with you there my man.
Old Sep 8, 2007 | 05:31 PM
  #23
camarohelp's Avatar
I have the same problem.
I tried replacing the tach but it didn't help. A friend of mine with a 91camaro had a similar problem. He said he bought a new guage cluster and the problem went away
I've yet to fix mine...
Old Sep 10, 2007 | 12:35 AM
  #24
dhighway's Avatar
It's a piece of cake! you have to pull the headlight **** off, there,s a button that needs to be depressed, and then pull the **** all the way out, and your right 350rs theres 4 screws, you remove the plastic lens cover after removing the dash face, all you need to do is tilt the wheel all the way down , and pull out the top first then slide it to one side, but watch the odometer trip button and then roll it out around the column. there is two brass connection contacts that the cluster locks into, if you clean these contacts with a cuetip and alcohol, it very well could correct your tach problems, just be careful not to touch the back to much if you do wipe your finger prints off. good luck.
Old Sep 10, 2007 | 08:33 AM
  #25
FunkyColdMedina's Avatar
Thanks for all the input guys... looks like this will be a weekend project when i have time off from school or what not!
D67
Feb 17, 2015 02:23 AM
santa6
Jan 12, 2012 09:01 PM
williambubeck777
Jan 26, 2010 07:09 AM
A Stinky Bumb
Sep 26, 2009 11:27 PM
73camaroSS
70-81 V8 Tech
Mar 5, 2008 02:12 PM
