removing a seized fuel filter????
one of the fittings is seized on my fuel filter. how can i got about removing it without stripping the threads? i know using a torch to heat it would be a retarded idea.
I have never had a problem when using tubing wrenches and putting them both on where they are close enough to squeeze with my hands to break them loose. Tubing wrenches work way better than an open end wrench. And when things get rounded there are some vice grips for that. It has one side a "U" shape and the other jaw fits in it so it kinda works on 3 sides.
ORIGINAL: microkid
I second the tube wrench idea. They work WAY better than a regular wrench. Spray it with
Liquid Wrench, let it sit, then hit it with a tubing wrench. It will come off.
ORIGINAL: ScottD
At least you realized it beforehand. I cant tell you how many times Ive done things and a minute later said "damn, that could have gotten ugly....".then I count my fingers.....
ORIGINAL: microkid
well, i dont have a torch anyways. but the filter looked like it was installed just before i got the car. the owner told me he had a lot of things serviced while the car was in for the tranny, and looks like fuel lines and a filter were some of the things.
johnson3034
May 25, 2007 09:35 PM
