Rebuilding rear axle
Old Aug 21, 2005 | 11:17 PM
PrinceCharmmin's Avatar
Default Rebuilding rear axle
Hey, I need to rebuild my rear axle. I know I can fit an axle out of a z28 in my car witch come with disk brakes. Which is some thing I want to add to my stock axle if I end up rebuilding it… I guess what I am trying to ask is should I rebuild my stock axle or rebuild one from a Z28?
Old Aug 22, 2005 | 12:29 AM
Default RE: Rebuilding rear axle
Make your life easy, get a complete axle with disk brakes, calipers, rotors. etc.. If you get a good one you may not have to rebuild it. Otherwise you will have to hunt up all the parts for the disk brake conversion, plus rebuilding the axle.
Old Aug 22, 2005 | 01:35 AM
Yeah... I was looking for a direct bolt on axle brand new that could handle some big hp but it doesn’t seem like I can find anything but I known they are out there…. Like a Borg-Warner or DTS…. But it sees like every thing has to be custom fitted…
Old Aug 22, 2005 | 12:47 PM
Old Aug 31, 2005 | 07:48 PM
90rs's Avatar
if i was going to want posi would i want to add a limited slip or find a rear end and rebuilt that had posi?
crazyleroy
Aug 13, 2012 06:29 PM
camaroluver
Apr 5, 2011 09:26 PM
maudyZ28
Mar 10, 2010 08:22 AM
camaroguy992007
Sep 14, 2008 05:55 PM
muscleman
Sep 17, 2007 11:36 AM
