Rear Axle Width
Old Feb 18, 2007 | 12:17 AM
IanM's Avatar
Default Rear Axle Width
Hi all, just wondering what the wms-wms is on the stock rear axle? what applications would provide suitable donor axles? I'm thinking 12 bolt chev, but don't know what to pull it from.
Thanks,
Ian
Old Feb 18, 2007 | 12:18 AM
IanM's Avatar
Default RE: Rear Axle Width
BTW- I'm assuming that all third gen camaro's have the same rear axle, but with different gear ratios
Old Feb 18, 2007 | 02:30 PM
blackz87's Avatar
ORIGINAL: IanM
They came with both 9-bolt(until 1989) and 10-bolt rears and will fit on all 3rd Gen models. 4th Gen rears will also work, however they are 4" wider (2" per side).
Ratios:
9-bolt----3:08.2:77,3:27 and 3:45 and very few 3:73
10-bolt----3:08.2:73,3:23 and 3:42 (same for 4th gen rears)
RPO G80 limited slip & J65 rear disc brakes were a extra cost option andwere not on every rear axle. Spline count was 26 until mid 1989 when changed to 28.
Old Feb 18, 2007 | 03:40 PM
IanM's Avatar
thanks for the reply. If I were to upgrade to a 12 bolt, any idea what vehicles I could take the axle from and what the wms would be?
Old Feb 18, 2007 | 03:45 PM
blackz87's Avatar
You can't use rear axles from other cars, theywill NOT work without expensive fab work, Special order 12-bolts are in the $2500 range.
Old Feb 19, 2007 | 10:12 PM
IanM's Avatar
here i thought chevy built a few vehicles with interchangeable axles....what would make it not work? just the axle widths?
Old Feb 19, 2007 | 10:55 PM
blackz87's Avatar
ORIGINAL: IanM
I won't try explain the differences. Look under your 3rd gen car and then look under whatever 12-bolt GM you think will fit. End of story.
Old Feb 20, 2007 | 12:32 AM
IanM's Avatar
ORIGINAL: blackz87
I don't have a 3rd gen yet...but i'm buying pieces for it. Thanks for the help
crazyleroy
Aug 13, 2012 06:29 PM
maudyZ28
Mar 10, 2010 08:22 AM
57buick
Oct 19, 2007 08:01 PM
muscleman
Sep 17, 2007 11:36 AM
nebt3x
Mar 8, 2007 03:52 PM
