87 rear end width
Old Oct 19, 2007 | 04:54 PM
57buick's Avatar
Default 87 rear end width
Does any one know the width of a 87 IROC rear end? I am building a 57 Buick and have a79 Z28 subfram and have found a deal on a 87 rear, but I am not sure it will fit.
Old Oct 19, 2007 | 05:13 PM
Arizona Camaro's Avatar
Default RE: 87 rear end width
I would go with a 12 bolt or even an earlier 10 bolt before I would put a 3rd gen in there. They break way too easy as it is and an additional 1000 pounds or so wouldn't be good
Old Oct 19, 2007 | 06:37 PM
MadMikeZ28's Avatar
They are not as weak as the other person makes them sound. Any rear will break under abuse.
I could go a measure but to start off with do you know that they will not directly bolt into the 79 sub frame that you have. Third gens started using control arms and coil springs. So if that is still what your looking for I will crawl under my car unless some one else beats me to the answer.
Old Oct 19, 2007 | 07:50 PM
57buick's Avatar
The Buick had rear coils back in 57 and my fabracator say he can make any rear work. The front sub fram is olny from the fire wall forward. With that I get disc break up front. I was going to go with an older 10 or 12 bolt but this way I get disc on the rear too. Is the disc breaks worth the strength issue? I an putting in a 350 creat motor that should make about 330 HP. Not looking for a race car just a more update suspension and drive tran.
Old Oct 19, 2007 | 08:01 PM
57buick's Avatar
By the way he say"THIS IS THE REAR FROM MY 87 IROCK CAMARO10 bolt IT WAS JUST PULLED FROM THE CAR IM PARTING ITS COMPLETE WITH DISK BRAKES NOT SURE THE GEARS THAT ARE IN IT should be pozi" From what I have seen all 87 IROC came with posi and gears from 2.73 to 3.23. Is this right?
imcdowel
May 8, 2012 01:09 AM
acdc686
Oct 20, 2008 03:38 PM
IanM
Feb 20, 2007 12:32 AM
PrinceCharmmin
Sep 3, 2005 10:02 PM
freshmanit
Aug 11, 2005 01:34 AM
