Problems With Installing Tranny
Old Mar 23, 2006 | 05:36 PM
Bigrob92rs's Avatar
Default Problems With Installing Tranny
Hey all,
I am having some problems installing a transmission. The problem I keep encountering is that I recently purchased a 89 TBI 350. and I am having some issues getting the transmission to bolt up to it. The bell housing when i finally get it to bolt up the troque converter wont spin freely to put the flywheel bolts in and yes the ttroque con. is in all the way. I also have to use some bolts to line it up and pull it together slowly since it wont slide together like the stock. I am trying to use the stock transmission, since i recently had a stock enigne i will be using that same tranny. which i think is a 700-r4 trans. The mechanics I talked to told me it should fit fine together but it doesnt and I have tried multiple times. Anyone have any ideas it would be appreciated.
Old Mar 24, 2006 | 07:19 PM
adrenilinjunki's Avatar
Default RE: Problems With Installing Tranny
i had problems like this to the fly wheel ended up being on backwards
Jmoss13
Apr 7, 2010 01:04 PM
Jakobzara
May 9, 2008 12:29 AM
thadd154
Feb 10, 2008 11:54 AM
hurley870
Jan 28, 2007 11:55 AM
Bubonic
Sep 1, 2006 10:10 PM
