Over heating problems 90 camaro
I'm making this for information on over heating problems.
If your car is over heating while idling check the FAN. don't get a crappy cheap fan with no pull!! if fan doesn't spin but is in still good condition JUST grab another motor for it!! next check the thermostat, I've been putting in a 190 and 195 thermostat like oem suggests and it just runs too hot that way. dropped it to a 180 and it's great!!
****KEY
if your engine is over heating while driving, (I never see anyone say to check this because it usually is just taken for granted I think) CHECK YOUR air flow !!!! These cars were built to get constant air flow to their radiator through the in the front of the car. If they are not aligned straight to the Radiator you're going to have problems.
ALSO check your AIR DAM...air hits it and travels up to the radiator to keep it cool!
rarely do I see people talk about these two things when over heating is mentioned. I fixed my Camaros over heating problem just by fixing the air dams and adding that wind bar on the bottom.
****KEY
