camaro heating up!!!!
Old Apr 24, 2006 | 02:55 PM
coolcat's Avatar
Default camaro heating up!!!!
Ok my car keeps on heating up, i already changed the thermostat (190) i changed that sensor near the intake what do i do
89 RS 2.8L
Old Apr 24, 2006 | 03:14 PM
blackz87's Avatar
Default RE: camaro heating up!!!!
Do you have the air dam under the car ????
Old Apr 24, 2006 | 10:50 PM
Are the fans comong on when engine is hot??
Old Apr 25, 2006 | 01:38 AM
coolcat's Avatar
sorry i responded so late z28pete the fan turns on when the engine reaches the top on the heat meter in the car. the fan turns and cools the engine slightly, but it turns back off. What is the right temp. for the engine? the dude at autozone said that i might have more water than coolant?? what do you think
Old Apr 25, 2006 | 02:16 PM
coolcat's Avatar
come on now does anybody have any other suggestions?????
Old Apr 26, 2006 | 05:04 PM
67454conv's Avatar
have you checked to see if you have a air bubble in engine you might try taking the heater hose off and fill engine through hos just in case there is not enough water to also fill heater core. As for to much water drag cars are not even allowed to run antifreeze (atleast according to the rules) and they cool water wetter will help cool it down some if it so happens you have to much engine for your radiator
B_Dubya
Sep 2, 2013 01:11 PM
camaroboy68ss
Oct 27, 2011 11:30 PM
bcbarbie
Jul 13, 2011 07:36 PM
Adrian'sCamaro36
Jul 9, 2009 10:04 AM
Eric89RS
Jun 9, 2009 03:09 PM
