non t-top leak
Old Mar 23, 2007 | 07:54 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default non t-top leak
i just sealed the area between the glass and rubber, and the rubber and the body. i still have two leaks though. one is behind the driver seat, and comes off the corner of the plastic peice on the roof. where could that be comming in at? the other leak is on the passenger door, at the very front. im going to run some silicone along the rubber there as well, and hopefully that works. but i cant figure out where the leak behind me is comming from.
Old Mar 23, 2007 | 09:04 PM
blkmgkcamaro's Avatar
March 2007 ROTM
Default RE: non t-top leak
its mostly luck with camaro t-tops. sometimes they leak, and sometimes they don't. its the same with the corvette...just the times and technology or lack of i should say. even with new weatherstripping my dad's corvette still leaks a little.
Old Mar 24, 2007 | 04:06 PM
microkid's Avatar
March 2011 ROTM
Technical User
i found two spots that i could probably add some more silicone on the top to repair the rearward leak, and i think i may have found the one on the front
Jelz28
Jul 18, 2012 06:01 PM
95mero
Jan 5, 2009 09:14 AM
derrickdiggler
Oct 12, 2007 01:22 AM
derrickdiggler
Sep 27, 2007 02:26 PM
daltons 1980
Sep 24, 2007 09:04 AM
