non startin piece of ****
Old 07-30-2007, 11:35 PM
dhighway's Avatar
Default RE: non startin piece of ****
Well then if you had a serious backfire! it is quite possible you have unloaded the lifters!! it happened to that target master, she backfired hard and tore the skin of the muffler, unloaded lifters will not allow the valves to open properly, and will change with every crank! pull the intake and lifters soak them in a can of oil, for a day or so! or you can reload them with a manuel pump oil can. just an idea! might be the problem. Good Luck.
GLENN M
82-92 V8 Tech
02-02-2011 06:04 PM
fishbone
82-92 V8 Tech
11-07-2010 10:58 PM
eric_m96
05-12-2006 08:07 PM
kelsroc
08-29-2005 06:21 PM
Quick Reply: non startin piece of ****
