No power on injectors?
Old Jul 13, 2014 | 05:30 AM
PRJCTRS's Avatar
Default No power on injectors?
Hey everyone, I am new to this site. Okay, my problem is I don't get any voltage on both injectors when key is on and no ground on ecm as well.
Here's my story, the passenger side injector used to be working fine which I get voltage and ground. Not until when i decided to swap the good connector to the bad connector and plugged to the injector which is on the driver side.
I unplugged the four wires that goes to dist. (ICM) purple/white terminal and used a test light to make it touch and untouch the purple/white terminal the driver side and injector sprayed out gas.
Now when I plugged the working connector back to the passenger side injector and tested for voltage and ground it's no longer getting any power? I don't know what went wrong.. I really hope you guys can help me out
91 CAMARO RS TBI
92Z
82-92 V8 Tech
Aug 28, 2015 04:30 PM
xXChipXx
LS Series Tech
Sep 25, 2011 05:59 PM
robbies_z28
Apr 19, 2010 11:34 AM
Ogamuk
Oct 31, 2008 08:11 PM
carguylt1
Nov 18, 2006 11:57 PM
