injectors
Old Oct 25, 2006 | 05:09 PM
carguylt1's Avatar
Default injectors
I'm replacing the cam and valves my cam is the lt4 hot cam my valves are 2.02/1.60. what size injectors do I need?
Old Oct 25, 2006 | 05:13 PM
shnormo's Avatar
Default RE: injectors
I'd go with the 35lb/hr injectors. It'll let you have room for even more horse power.
Old Oct 25, 2006 | 05:15 PM
uncle bill's Avatar
I don't feel that You need any larger injector than stock. If You haven't done it already, try to stay away from the 2.02 Intakes. I've built a lot of these engines and have found that 1.94 intakes with 1.60 exhaust make as much horsepower and keeps the torque up .
Old Oct 25, 2006 | 09:37 PM
Whatever set up you choose, get the PCM reprogrammed to take all your mods in consideration. Otherwise the engine won't make as much power as it is capable of making, and you may driveability issues.
Old Nov 18, 2006 | 11:57 PM
y2kCamaroSS's Avatar
i think you can just use the stock injectors..im still running stock injectors on my car no need to upgrade just yet
lt1z2896
Mar 6, 2010 05:52 PM
Cris
Jan 24, 2010 03:48 PM
joeSScamaro
Sep 4, 2007 02:49 PM
8485Chevycowboy
Jul 11, 2007 03:45 PM
sepadowd
Jun 15, 2007 08:50 AM
