No Handbrake
Old Jul 4, 2005 | 12:51 AM
auscam's Avatar
Default No Handbrake
Hi Folks, I just bought a Z28 1984 and its got no handbrake at all. all the mechanics work fine but the back calipers do nothing when the handbrake is engaged. Is there any adjustment??? or is there a kit I need to put through the calipers to make the hand brake work??? any advise would be greatly appreciated .....Cheers Mark
Old Jul 4, 2005 | 01:55 AM
Boost's Avatar
Default RE: No Handbrake
my 83 is the same way. There is an adjustment underneith the car. Look around and see if you can find it. it should be at the split for the hand brake cables. Also there should be an adjustment on the hand brake inside the console...
Old Jul 4, 2005 | 08:15 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
most likely the bars in the back brakes are shot, and you just have to buy a kit for it. also, you must adjust it afterwards
Old Jul 4, 2005 | 09:41 PM
Boost's Avatar
ORIGINAL: nj85z28
U know, ur right. I didn't even think of that. I tried the simplest thing...[:@] Doh!
Old Jul 11, 2005 | 12:37 AM
auscam's Avatar
Guys thanks for all your help. Put a kit through the back brakes and fixed the problem...cheers
Amy Z28
Nov 26, 2013 07:56 AM
Organgrinder010
Apr 1, 2011 08:00 AM
oliverjohn
Jan 14, 2009 09:25 PM
auscam
Jul 12, 2005 02:34 PM
