New to camaros
Old Mar 15, 2011 | 02:05 PM
Massey's Avatar
That air dam is what helps push the air under the car up into the radiator. If you dont have one GET ONE!! It is critical like ScottD is saying.
If you have a 195 T-stat in the car then running just below the 220 mark sounds right. You have a carb on that engine right? Rule of thumb, 180 for carb and 195 for FI.
Your engine, when shut off will continue to "heat up" a little. This is simply the water absorbing the heat from the cylinders and not able to disipate it through the radiator. Why it didnt go down as you drove home I dont know unless your air dam is gone, or your fan clutch is not working.
Leave the fan shrouds on and alone they are also a big help to air flow.
Massey
Old Mar 15, 2011 | 02:06 PM
Massey's Avatar
TIG this is an 83 Z there were no electric fans on it. These still used the spring thermal clutch fans.
Massey
Old Mar 15, 2011 | 07:24 PM
torque_is_good's Avatar
Massey
wow, is that old stuff butttttttttt, the same holds for when driving at 30mph or greater, The car shoud be running close to thermostat rating ie: 180, 195 etc
Old Mar 15, 2011 | 09:03 PM
Mr.Dz28's Avatar
ok i have the air dam i saw it last night and, its not broken or anything. I do have a clutch can and that thing is pulling air real good. Friday im going to do timing chain water pump thermostat, spark plugs and valve cover gasket. ill let you guys know whats up when i get done friday afternoon.
Old Mar 16, 2011 | 10:53 PM
Mr.Dz28's Avatar
ok so just to recap. My engine was doing just fine. this whole time it was my gauges, It had a bad connection on it and a couple of bolts missing on the cluster which made it move around and get wrong readings haha.
Old Mar 17, 2011 | 05:37 PM
Massey's Avatar
Glad to hear that the fix was a simple one. So when ya gonna post some pics for us to see?
Massey
Old Mar 19, 2011 | 05:56 PM
Mr.Fitzkee's Avatar
Originally Posted by ScottD
NO! There is supposed to be a large, flat strip protruding from below your cars nose. Its very easily damaged by curbs...and often removed by unknowing owners. This 'air dam' is CRUCIAL to your cars cooling system. Dont even think about replacing anything until you verify if that dam is in place or not.
How do you know if the air damn is damaged or not? My car always overheats when i'm not moving.
I've replaced everything that has to do with the cooling system except the radiator, but i had the radiator rodded out and rebuilt.
Old Mar 20, 2011 | 10:29 AM
ScottD's Avatar
Your air dam is an unmistakable big piece of black plastic trim under the car. You cant miss it. If its broke, it will either be missing giant pieces (from curbs, etc) or missing all together.
You had a radiator rebuilt? That seems a bit overkill when a replacement radiator is around 100 bucks. If you are overheating while sitting still, you need to check everything. Look for any debris obstructing your radiator as well. My bet is your rebuilt radiator wasnt rebuilt so well or your fan clutch isnt working right.
Carkid70
Oct 15, 2010 06:42 PM
RFxCamaro
Jul 21, 2008 03:21 AM
