New Brakes
Old Aug 14, 2006 | 08:02 PM
Goodfella's Avatar
Default New Brakes
The rear drum brakes on my 91 RS have about 5 % left on them and I was wondering if I should swap to rear disc or just get better drums. The front discs have about 85% left on them. What do you guys think would be better? Also if I did get rear discs, would i have to get equivalent new brakes in the front? I could spend anywhere from $600-$850; Are ther any good kits that are that cheap. Even a Junkyard might have something. Right?
Old Aug 14, 2006 | 09:27 PM
Default RE: New Brakes
You are not going to see thst much difference by replcing rear drums with disks. The reason that they are worn out is that no one bothered to replace the rear shoes when the front pads were changed. Rear brakes usually outlast the front brakes by a large margin because they have much less work to do. If you swap, there is more involved than just bolting up a set of brakes from another car. You are going to redo the psrking brske cabling, change proportionong valves, & probably some other stuff.
The front and rear brakes have to be a matched set, otherwise the end with too much braking power will lock up & cause a skid.
Old Aug 15, 2006 | 01:07 AM
Goodfella's Avatar
You do have a good point; that was the answer that I was looking for --> I think I will just get new shoes in the rear.
Thanks man
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
