need some please
i am working on a 87 camero z28 305 with a carb,
the problem started when we thought the fuel pump quit so we cut a hole in the rear deck and changed the elect pump , not knowing it was a low pressure pump i changed it to a 58lb pump had all kinds of trouble then i realized it had one on the block also so i changed the tank to a low pressure pump , kn i have a bad mis so i changed the carb no luck , i changed all plugs and wires , cap and button , so now i have a code ( TPS ) i did all the test and yes it must be bad m i have voltage from the TPS, could that cause a mis? i also used a vac guage to adjust the carb and didnt have a change by adjusting the 2 screws on bottom of carb plate , so what i am thinking is i might have a bad intake gasket or head gasket , because when the high pressure elect pump was on i had a lot of gas in the old carb enough that it would not crank over i had to remove all the plugs first ,
sorry for the long post , but i dont know were to start now
thanks please help
thanks please help
update
here is were i am now ,
i found the adjustment for the TPS and got it to 0 after i got the idle right , i tried to adjust the fuel /air mixture screws , got them to were i think it runs the best ,, then checked the idle and also checked the TPS voltage again it runs ok but still had a slight mis , i am going to check plug wires again i dont know what else to do at this point , i hope i dont have a bad carb
info please ?
info please ?
chrisearly
Aug 4, 2012 11:37 PM
