Need advice
If you want a good rebuild, bore it .030" over. That doesn't make much difference on the cam, it only gives you a 355 as opposed to a 350. 1800rpm+ range on the cam will do good in the city and highway with a 2200-2300 stall converter, and if you have an overdrive transmission with a lock-up converter you'll be fine on the highway.
sohcnick
03-25-2013 04:03 PM
1981camaroz28
10-23-2007 05:44 PM
