my rearend
ORIGINAL: noquarter05
1992 z28
Does anybody know the size/ratio that would come with this??
1992 z28
To make really sure, pull the rear cover and count the theet on the ring & pinion gears and do the math, the pinion may even be stamped with the ratio. Also a good excuse for changing the rear end lube.
do the math like pete said but he forgot to say the equation.
count the teeth on the ring gear, and count the teeth on the pinion
divde the number of teeth on the ring gear by the number of teeth on the pinion
#of ring gear teeth divided by # of pinion teeth
All Gear & Pinion sets regardless of MFG have the gear ratio stamped on the gear OD. So it a easy way instead of counting the gear teeth. Because sometime people can't count over ten using the hand computer.[sm=chairshot.gif]
