molding on driver door
Old Jul 7, 2007 | 10:56 PM
1990 Camaro RS's Avatar
Default molding on driver door
does anyone know where i can get the molding that goes across the driver side door on a 1990 camaro rs
Old Jul 7, 2007 | 11:08 PM
zeus8807's Avatar
Default RE: molding on driver door
the ground effect or the door guard, ground effect either junk yard or hawksthirdgen, if you bean the door guard, im not sure which was on the rs, if it was the black rubber peice or the nice painted stuff that was round at the end, if its the black you can get it at all auto parts store comes in rolls, the painted stuff, they discontinued the stuff for third gens, but i know some of the 4th gens came with a pretty similar product that gm dealers should still be about to get, or you can go to the junkyard and get some and just romove the old glue and put on new.
Old Jul 8, 2007 | 01:11 AM
MadMikeZ28's Avatar
The 4th gen stuff wont work. There is a groove in the body line that the molding sits partly in. You can also check automotive paint stores. It will also come in a roll that will need painting. Even at times when you got moldings from the dealer they would come painted white or the gray primed. You can check a dealer for NOS but it may be exspensive.
Old Jul 8, 2007 | 11:36 AM
it was the door gaurd molding and hawks third generation had it but color varys because it off used camaros so ill probally need to paint it white
puma
Aug 1, 2011 10:26 AM
joeincalgary
Jun 24, 2010 08:15 PM
mccoyj91
May 20, 2010 12:45 PM
mikebrow74
Feb 14, 2009 01:56 PM
coldtexan
67-69 V8 Tech
Jul 12, 2007 09:19 PM
