max hp for 305
Old 02-04-2010, 07:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
i blew out the crank and rods on a stock bottom end with just a small amount of added power. free flowing intake and exhaust and ignition componants. see the pics in my photo gallery, its epic
Old 02-04-2010, 08:07 PM
tbl76camaro's Avatar
Nice
Old 02-09-2010, 06:51 PM
yankeeboy's Avatar
I dont know what ye guys would think of this but i thought id just show incase someone would be interested: http://cgi.ebay.com/ebaymotors/ws/eB...87340569520281
Old 02-18-2010, 06:37 PM
Sinclairaity's Avatar
here's a way to almost get 350 hp with a 305
http://www.hioutput.com/tech/343hp/343hp.html
still recommend getting a 350 though. With spending all the money on this. It will be much cheaper to go with a 350. Heads and cam on a good 350 will make some decent power for not to much money. All depends how crazy you wanna get
Old 03-16-2010, 05:27 PM
82Camaro's Avatar
I have a 305 that i had bored out 40. over and put in new pistons,rings, mild cam,plugs,turned crank, and bearings. I didn't put it in my Camaro yet but will soon hopefully.I'm just wanting something with decent power but not a racer.
Old 03-17-2010, 02:28 AM
hurley870's Avatar
[QUOTE=Gorn;397880]All a turbo does is add air and that is all Nos does.
[QUOTE]
Actually NOS is nitrous oxide, sprayed like the air/fuel mixture in the cylinder. It burns quicker and colder, which creates the "boost." NOS does not just add air...
Plus NOS would blow the motor just as fast as a turbo if it isn't built to handle it.
Old 03-25-2010, 09:09 AM
ballerxforxsho's Avatar
oh my godd, i didn't even read all the posts. go with a 350 small block. more power for less money. most 305's are dogs. and turbo? a turbo? what is it a camaro or honda civic? no, all motor or supercharger.
Old 03-25-2010, 11:55 AM
freaky's Avatar
you ****ers crack me up some days ..
lets look at shall we :
supercharger forces are in by being turned with a belt / pulley run off the motor .
turbo forces air in by being turned by exhaust gases . so if a turbo is rice then so is a supercharger , so your attempt at being a smart *** really just makes you look like a dumb *** .
plus with a turbo an the right setup you can up the boost on the fly, i'd like to see you change a pulley at wot .
Old 03-25-2010, 02:29 PM
1990CamaroRS's Avatar
Fancy Sparkle
check your facts. Earths atmosphere is 70% NITROGEN. N2O is is pretty much just bringing your own air.
  #20
Old 03-25-2010, 04:37 PM
freaky's Avatar
your part right but n20 explodes under pressure an heat which realy gives the boost (other wise you could just hook up granma's oxogen bottle an do the same thing ) thats why n2o is so dangerous an why you can get n2o backfires in the manifold .
