LT1 Swap info wanted
So I have decided to drop an LT1 into my 91 rs but i didnt know where i could get a good replacement LT1. I was looking at scoggin ****ey but i couldnt tell the difference between them all. Heres the site http://www.sdpc2000.com/catalog/3832...te-Engines.htm . Would it be better to get a turn key type crate or a partial and build it myself, or even to check out a local junkyard. PS what other parts would I ned in order to successfully swap the engine ie: t56 tranny, driveshaft, rear, axle, ecm, wiring harness, ..... anyhing else? (assuming the motor comes turn key) Thanks --Kevin
