Loose rattling door handles and glass
Ok So i have been looking at why the doors are rattling. The hinges have to be replaced but the door handles are loose, Does anyone know if there is a spring under the handle that keeps it tight?
I noticed the doors have window sliders that are really worn and allow the glass to move about. Does anyone know where I can get these parts.
i have looked at classic industries, butu nothing yet. i may have to fabricate my own to get that solid door feeling.
Well Caveman I did find out that there is supposed to be a spring just under teh handle and cant find anyone that carries it yet. I have found a post somewhere that shows hobby shop fuel line on the rod connecting the handle to the locking mechanism. this should stop the rattlling of the door handle.
I opened up my door and noticed that the exterior door sill was worna nd the screws just spind onto the door.
I will be ordering a new door sill.
In the meantime I have added a shim of plastic behind the sill and added terry cloth to the sliders. Then i readjusted the inner sliders to keep the window snug.
Some of the rattling has been eliminated.Window up or down.
New felts would be optimal. But why not add felt material to the old sliders. The only reason why i want to get the outside sill is becasue the rubber is cracked and bent. My door is nice and snug now after temporarily fixing it by adding material. The only problems left are the door hinges are sagging and the door handle rattles. Besides that im good to go.
Oh and since I added material and it keep s the window from ratling it also gives me a better seal and no more whistling of wind.
I'll be Adding material to my window guides and everything since my door panels are off so i could do body work
i may buy new handles but will prob just add the rubber hose to stop the rattle for now
thanks for the info on the spring, im sure mine went missing when the P.O. hit something on the driver side, as thats the only side that has problems with anything rattling
I didnt understand how those springs can become missing until my first ice storm. i tried to open my door and I almost needed a crowbar to pry the window from the weather stripping.
i guess thats what caused the sprng to come loose
