Looking for a softer clutch
Old Dec 18, 2010 | 07:03 AM
Rjklement15's Avatar
Default Looking for a softer clutch
Im getting ready to pull apart my Z28. And I really need a Softer clutch. My feet are all messed up and weak from nerve damage resluting from a motorcycle accident.
What do you guys know for clutches that wont be as stiff or any other ways to help.
Thanks in advance
Old Dec 18, 2010 | 06:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
oem replacement is the softest you will get. is it a hydraulic or mechanical linkage clutch?
Old Dec 19, 2010 | 09:00 AM
its an 83 So its mechanical... i wonder if i could put a hydraulic linkage in without it costing a fortune
Old Dec 19, 2010 | 02:23 PM
Anything that will improve the leverage is going to result in longer pedal travel, wether it be a mechanical system or a hydraulic system. A 6 cyl pressure plate, if it fits, may help, but you will need to drive very gently. Condidering your health problem, an automatic would be a better choice, and the performance won't differ much.
Old Dec 21, 2010 | 08:30 AM
It wont really cause much of a problem. It will just take a while to adjust to. A softer clutch will be more comfortable, however I do realize im driving an 83 Camaro. My Daily Driver is a stick and i drive it no problem.
After a few drives I should have it no problem. In fact... it may actually help my feet out.
Old Dec 21, 2010 | 08:06 PM
microkid's Avatar
March 2011 ROTM
Technical User
if you were really crafty, try to make a small brake booster to assist with it.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
