LG4 to TPI swap
Old Oct 8, 2010 | 08:30 PM
Buffalo02Z28's Avatar
Default LG4 to TPI swap
So my father wants to swap out the almighty LG4 305 in his '83 Z28 with a 350 TPI that came out of a '91 Camaro that is for sale. The 350 TPI engine is complete and comes with intake, emissions manifolds, OE wire harness, injectors, ECM computer, and a complete 700R4 transmission. If we purchase this combo, we plan on using the engine like I said and bolting it to the T5 transmission that the car is already equipped with. We don't plan on including the 700R4 into this project. So my question is does this package include everything that we need to perform the swap if we decide to purchase the package? And how difficult is this swap going to be?
Old Oct 8, 2010 | 11:03 PM
Come on people, has anybody ever performed this swap?
Old Oct 10, 2010 | 06:34 PM
microkid's Avatar
March 2011 ROTM
Technical User
sounds like you got everything you should need. the later model block (as i just found out) moves the oil pressure switch and sending unit to above the oil filter. you will need to lengthen the harness and get adapter fittings as they are a different thread pitch. im going to try lowes tomorrow to see if i can get the parts i need to run that. also, running the t5, you will need the flywheel and clutch (if different) from an 87 and later engine. the switch to a one peice rms mandates that. im sure there are some minor things you will have to change, and have fun routing the wiring harness
Old Oct 10, 2010 | 07:38 PM
Yeah I read about how fun it is to route the wiring harness. I think my father and I are going to pass on the TPI motor. We think that it would be easier to just buy a longblock 350 and use the LG4 carb. I read that it is also easier to make more power that way than with the TPI.
Old Oct 11, 2010 | 10:40 AM
InjectorsPlus's Avatar
There will be no power difference between a carb, TPI, TBI, or MPFI motor. The peak power will be the same regardless of fuel delivery.
Injection will give you better starts, better mid range, better idle.
You can run a bigger cam with a smoother idle on an injected engine since it does not require vacuum to operate. It's electronic.
Old Oct 11, 2010 | 07:20 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, the carb will be easier and much cheaper in the long route. im about $2k into my existing tpi setup, and i havent even touched the intake yet
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
