intake manifold or cam?
RE: intake manifold or cam?
ORIGINAL: MadMikeZ28
I had that one on my 84.
No adapter. You can see by the pic it is open for the larger secondaries on the Q-jet.
It will raise the hight of your carb and air cleaner I think 1/4". My hood still closed with the stock air cleaner but you could see where it slightly rubbed on the hood insullation.
And if you are using the stock air cleaner there is a ring in it around the opening for the carb. When the lid is bolted on it closes up cutting off air. Three spot welds to grind and that ring pops out. A cheap and FREE mod.
