the impossible-to-find starter
Old Mar 6, 2006 | 10:32 AM
jrad350's Avatar
Default the impossible-to-find starter
I am working on a 1984 Camaro for a friend. I am a Mustang guy (sorry) and am new to the world of Chevy. The car had a 305 from the factory, and currently has a fresh 1974 350 4bbl from a Malibu or other large passenger car. The car also has (I guess) the stock drivetrain (Auto tranny, flexplate, ect.) from 1984. So with the 1974 350 Stock 1984 tranny & flexplate combo it seems to be impossible to find a starter. The starter that was on the car with the older 350 that was blown had a straight bolt pattern for the starter. The Motor we put in it has the staggared bolt pattern. The problem with all the starters I can find (I looked at almost every starter at my local Auto Zone) is that the starter motor is HUGE, and when bolted up, the teeth on the starter miss the flexplate by about 1/2". So aparently the starters with the staggared bolt pattern are made for use with a larger flexplate/torque converter combo... Am I missing something, or does Chevy not have a starter for this combo? Thanks -Ben
Old Mar 6, 2006 | 12:49 PM
Default RE: the impossible-to-find starter
Most Chevys hadd either a 153 or 168 tooth flywheel/flexplate. Apparently you hav the small 153 tooth flexplate, so you need a starter for the small flexplate. Check with Summit or Jegs, they list a good assortment of starters.
Old Mar 6, 2006 | 07:10 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
i would also suggest on the third gen, finding one with a very high resistance to heat, to avoid heatsoak
Old Mar 6, 2006 | 08:15 PM
jrad350's Avatar
i was looking for a stock chevy replacement...but I decided it wasn't worth the hassle and went with a quality Powermaster unit from Summit. Thanks for your help!
CamBigCat
Mar 9, 2014 11:46 AM
supersmoothpunk
Feb 26, 2011 11:22 AM
randolphdelpriore
Apr 8, 2009 11:32 AM
bezerker
Feb 2, 2009 12:23 PM
th3po1son
Aug 19, 2008 10:50 PM
