idle problem
Old Nov 22, 2012 | 06:37 AM
chrisz282010's Avatar
Its fuel injdected imma change the o@ sensor and change the fuel system wit all new lines and components
Old Nov 22, 2012 | 08:55 AM
blackz87's Avatar
Originally Posted by Paul86iroc
*1300
Not Normal for a 305, Idle is way to high by 100%.
Old Nov 22, 2012 | 01:06 PM
Paul86iroc's Avatar
Really? Because when it does idle at 500-750 rpm it's sounds like it wants to die and I took it to a mechanic to fix the electronic choke and tune on my qjet and he adjusted the idle to 1000 ish and also one of my friends has grown up around camaros all his life and owns a 76 z28 and says that's a normal idle for it?
Old Nov 22, 2012 | 01:54 PM
you may need to reset the base idle. check the voltage to the throttle position sensor. could also be the maf is failing or needs cleaned. should also check timing. should idle in the 800 range.
Old Nov 22, 2012 | 04:32 PM
Paul86iroc's Avatar
Alright thanks.. I bet it's the timing. I don't think I tightened the bracket all the way when I replaced it. Thanks again
Old Nov 23, 2012 | 08:18 AM
I changed the maf chdck engine went off but wen i turn the car on its fine then wen it warms up i guess thats wen the idle moves crazy and seems like its goin cut off then i would put it into drive do a burnout ..then it feels like it ran out of gas
liltonz23
Feb 14, 2012 06:58 PM
bryanpentlin
Oct 12, 2011 12:10 AM
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
sidewayz28
Dec 21, 2008 11:44 AM
72charger
Jul 17, 2007 05:58 PM
