idle problem
Old Nov 21, 2012 | 12:40 PM
chrisz282010's Avatar
Default idle problem
I have a 87 z28 car idles between 10-15 rpms and says low oil pressure but wen i press the gas rpm rise and oil pressure wat could be the problem and also what should the pressure be around
Old Nov 21, 2012 | 01:34 PM
hay chris welcome to the forum. i moved your thread to the 3rd gen section. should get a response soon.
Old Nov 21, 2012 | 02:13 PM
O thanks alot
Old Nov 21, 2012 | 03:11 PM
djs383's Avatar
Tach is laid out in 100's, so 10-15 would be 1000-1500 RPMS, As long as you have decent positive pressure 15+ you should be fine. Where on the gauge is it at idle and at say 2000 RPMS?
Old Nov 21, 2012 | 03:30 PM
blackz87's Avatar
1000 to 1500 RPM idlle is really on the high side. Should be between 550/750 RPMS. Adjust the idle or the IAC (idle air control) valve needs replaced.
Oil pressure should be high at 60PSI on start up and then drop after warm up to about 15 PSI at idle, Oil pressure will increase with engine RPMS,would be normal. No movement on the oil pressure gage could be the gage is not working or you have internal engine problems.
Old Nov 21, 2012 | 04:47 PM
slick's camaro's Avatar
How many miles on the motor. Gage could be worn out. Oil pump could be worn as well. You can grab a cheap one from the parts store if it bothers you. 1500 at idle is too much.
Old Nov 21, 2012 | 05:22 PM
Edwardgp's Avatar
Welcome Chris.
Old Nov 21, 2012 | 06:05 PM
The car has 184thousand plus miles.and its no vacum leaksxand oil is full wen i checked . Dis my first v8 so i need alot of helpso where would the iac be located
Old Nov 22, 2012 | 03:04 AM
Paul86iroc's Avatar
Is your 87 fuel injected or carb'd? Because I have an 86 305 carb'd and mine idles around 1000- 13000? And I was told that's Normal for the car. Do fuel injected and carb have different idle?
Old Nov 22, 2012 | 03:05 AM
Paul86iroc's Avatar
*1300
