idle help 86 305 tpi
Old Dec 27, 2014 | 07:38 AM
Rustyshackleford1911's Avatar
Default idle help 86 305 tpi
I've got an 86 z28/ irocz with the 305 tpi. From a cold start it doesn't want to stay running. It'll fire idle rough die. Takes about 6 or 7 tries before it idles ok. When I first fire it up and try to give it a little fuel and itll fall flat on its face, I was thinking something along the lines of an idle control sensor or something like that. What do yall think, this is my first camaro and first time tinkering on a sbc so I'm open to advice from some "veterans" :-) thanks for the help
Old Dec 27, 2014 | 09:32 AM
GaryDoug's Avatar
Could be the IAC valve. Try taking it out and cleaning it, but handle it gently.
Do you have a lit check engine lamp? If so, check for the code(s). Could also be defective engine coolant temp sensor, which may set a code. Or a defective cold start valve or a defective thermal sensor (no codes for those)
r00tk1ll
Feb 6, 2015 10:25 PM
hawkins183
Feb 15, 2012 11:34 PM
millspec96ss
Dec 12, 2009 10:47 AM
92rs_guy
Apr 9, 2009 11:20 PM
6v49der
Jan 3, 2007 01:51 AM
