Hood question...
Hood question...
Alright, I got my engine in yesterday, but I am still hooking everything up. However, I did find that I am going to have hood clearance issues. My question is, how rare are the stock fiberglass hoods that came on the crossfire injection cars? I am planning on just adding a scoop, but im not sure if I want to cut up that hood...
RE: Hood question...
Your manifold may only be around 1/4 taller than stock. If you use a low profile air cleaner then there should nopt be much problem maybe a slight rub. As for adding a scoop. Grind that one and bond a fiberglass scoop to it!
You understand that I was saying I have the stock fiberglass hood, right? lol
Between the performer intake, holley carb, and edlebrock pro flow intake, I am off about an inch or so. Lemme link you over to my thread on DF so you can see my post so I dont have to repost it:
http://dodgeforum.com/m_1372651/mpag...tm.htm#1372651
