Help, Small block accessory brackets.
Old Aug 24, 2009 | 12:04 PM
McGnrAcDcfan227's Avatar
Default Help, Small block accessory brackets.
So, im midway through rebuilding my 305 (yes, i know) in my 92 RS,
and i can't find that right bit to take off these brackets. I tried allen wrenches, no, a size 40 Torx bit,to small, a size 45, to big i've hit a wall. Help? These things need to come off so i can move on with my build, btw, somebody did some work on her in the past and torqued the bolts down WAYYY to tight, which is also a problem
Old Aug 24, 2009 | 03:00 PM
I had the same issue when changing the alternator on my 91 RS 305 (yes I know)!
I used a sharp cold chisel and a couple of good off-center whacks on the bolt head to loosen them. (be sure to strike it on the left half of the head to loosen) Then I replaced them with regular hex head bolts.
Old Aug 24, 2009 | 04:08 PM
yeah cool, your the man, but... i had one of the bits, and it fit, and it got out one of the bolts, but when i went to get out another, it was tight as hell. The torque wrench needle was well past 70ftlbs, and the tip of the bit sheared off
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
decaen
Feb 16, 2012 01:08 AM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
microkid
Mar 20, 2008 04:02 PM
