HELP!!! Mystery engine Casting numbers!!
Old Jan 26, 2008 | 03:32 PM
pyrofire127's Avatar
Default HELP!!! Mystery engine Casting numbers!!
I finally got the numbers off my block!!
can anyone findout what Engine this is?
5.7 350 TBI
block#K0322PJC
im calling rebuild shops right now asking them if they can look it up, but no luck so far
THANKS GUYS!!
Old Jan 26, 2008 | 08:49 PM
Jeramy's Avatar
Default RE: HELP!!! Mystery engine Casting numbers!!
get the casting numbers off the bellhousing flange on the back.i can't find that pjc suffix listed anywhere.k=st.catherines,ontario, 0322=march 22
what you got was the engine id code off the water pump flange right?
Old Jan 26, 2008 | 09:07 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Yeah, +1, get the casting number off the bellhousing on the engine, here is a quick sketch to show where it is:
Old Jan 26, 2008 | 09:45 PM
Jeramy's Avatar
mine were actually on the passenger side top but its a 86 motor dout that makes a difference but anyways i'm rambling.get the casting number up and then google chevy small block casting numbers and go through the list
Old Jan 27, 2008 | 03:40 AM
ok well the only thing i found on PJC was 88 gm truck... lol not good enough,
but IS there any easy way to get those numbers with the engine in the car fully installed?
Old Jan 27, 2008 | 11:03 AM
August 2009 ROTM
Yeah, get a light, stick your head back there and try your best to see it, lol.
palmers68
Apr 12, 2013 07:10 PM
MN79Camaro
70-81 V8 Tech
Feb 18, 2012 09:43 PM
mikes68
Jan 19, 2012 09:40 PM
Camaro_Boi69
Jan 12, 2009 10:28 PM
sweetquads
Aug 8, 2007 08:40 PM
