saginaw casting numbers
Old Dec 26, 2011 | 12:35 PM
mikes68's Avatar
Default saginaw casting numbers
just picked up 2 saginaw trans i think ones a 4 speed and ones a 3 speed casting numbers 3925647 shifts one dont but they where 2 cheep to pass up i hit a few sites to look up casting numbers no luck yet are the trans (case) the same for 3 and 4 speeds and just the insides different ??? can i make a 3 speed into a 4 speed ?????
Old Dec 26, 2011 | 02:47 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
its a 68/69 Camaro saginaw 3 speed
1967-69 Camaro Drivetrain Decoding
Old Dec 26, 2011 | 03:01 PM
mikes68's Avatar
thanks, can a 3 speed be turned into a 4 speed ?????????
Old Dec 26, 2011 | 07:34 PM
dynarider33's Avatar
Dont know what you paid for the transmissions, but even if you can convert a 3 speed into a four speed (I have no idea) it would probably be just about as much a finding a 4 speed Saginaw ready to bolt in by the time you bought all the internals.
Old Dec 26, 2011 | 08:53 PM
mikes68's Avatar
my daughters boy friend paid 100.00 for two 3 speeds one works fine for his nova project . all the trans we see on ebay or graigs list are 400 and up for a 4speed
Old Jan 19, 2012 | 09:40 PM
arocars's Avatar
Rebuild the four speed. It is inexpensive and if you are mechanically inclined, fairly straightforward. Lots of help on the web to do this.
palmers68
Apr 12, 2013 07:10 PM
MN79Camaro
70-81 V8 Tech
Feb 18, 2012 09:43 PM
oreocreaming
Mar 7, 2011 01:22 AM
Camaro_Boi69
Jan 12, 2009 10:28 PM
sweetquads
Aug 8, 2007 08:40 PM
