heater motor
Old Mar 6, 2010 | 08:45 PM
CMan84's Avatar
Default heater motor
i need some help guys! i replaced the motor in my 84 camaro and i only used the wires that i needed. after i plugged everything in and checked to see if everything works, the only thing that doesnt work is the heater. the blower doesnt work. well i noticed i didnt even plus the darn thing in. dont know where the wire went to. so i just hooked a wire from the battery to the blower to see if i had found the power wire for the blower. the blower gets power but it doesnt turn on. any suggestions?
Old Mar 7, 2010 | 12:02 AM
carguy68ssrs's Avatar
Are you saying that you changed the ENGINE in you car and now the heater blower motor doesn't work? Did it work before you changed the ENGINE?
Old Mar 7, 2010 | 08:45 AM
CMan84's Avatar
yes. i replaced the engine in the car and now the heater blower motor doesnt work but it did work before i changed the engine.
Old Mar 7, 2010 | 03:17 PM
does the plug for the blower motor have 2 wires or 1?
Old Mar 7, 2010 | 06:11 PM
microkid's Avatar
March 2011 ROTM
Technical User
give the blower motor power and ground to verify that it still works. there should be power to it at all times at key on, if memory serves me correct, and the resistors are in the ground circuit. check the fuse, wiring, and the resistor.
Old Mar 8, 2010 | 09:14 AM
CMan84's Avatar
the blower motor only has 1 wire. im just thinking maybe its the relay?
Old Mar 8, 2010 | 04:42 PM
ScottD's Avatar
Do I understand correctly that you just replaced the entire engine? (the powerplant) What you did was misplace some wires from your wiring harness or clipped a necessary connection. Think about it...it worked before the engine swap...now it doesnt. Do the logical thing first. Dont get lost in the sauce looking for burnt relays and such until you have ruled out all the painfully obvious stuff. Trust me, I speak from experience. I just redid my entire top end and my car WOULD NOT fire up yesterday. After 10 minutes of head scratching I saw I only had 2 of 3 pigtails hooked into the distributor.....
Old Mar 8, 2010 | 07:24 PM
microkid's Avatar
March 2011 ROTM
Technical User
there should be two wires to the blower motor. you seem to have lost one
Old Mar 10, 2010 | 12:00 AM
CMan84's Avatar
yes i realize that there should be 2 wires. there should be a power wire and a ground correct? i know i obviously cut something i wasnt supposed to. it also originally had A/C. would that ac unit ground out the entire system?
Old Mar 11, 2010 | 07:13 PM
microkid's Avatar
March 2011 ROTM
Technical User
no, anything from the a/c wouldnt control the blower motor. all of the wires for the a/c clutch and pressure sensors are small gauge (16) and the wires for the blower motor are large gauge (10-12)
Craig Ferguson
Apr 6, 2014 07:19 PM
wiskow
Jul 26, 2012 10:55 AM
kerbykk
Oct 26, 2008 03:47 PM
OldBruns
67-69 V8 Tech
May 1, 2008 12:57 AM
Booder
Oct 29, 2005 10:24 PM
