Head light switch broke - FIX??!?!?!?!
Old 11-23-2008, 09:09 PM
moparguy's Avatar
Default RE: Head light switch broke - FIX??!?!?!?!
My 1990 RS is the same way. The problem with it is the steering is loose. If I push the wheel in at about the 9:00 position and then hit the high beams they work. Its not the switch the steering has loosened up. Apparently its a common problem. I plan on tearing it down in a couple days.
  #22
Old 11-23-2008, 09:39 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Not much to tear down there bud, just the panels under the steering column, and then the two 10mm nuts that hold the steering column. Column drops right down, and the dimmer/high beam switch is towards the back of the column on the drivers side.
  #23
Old 11-24-2008, 05:23 PM
MadMikeZ28's Avatar
Those two nuts that hold the columns bracket are a lot bigger than 10mm
And that is not how you fix the loose column. To fix that, all the top of it has to come apart. Farther that replacing an ignition lock.
  #24
Old 11-24-2008, 05:58 PM
August 2009 ROTM
My bad, I didnt read it all and was thinking he was still talking about the dimmer switch...
And btw, I remember for a fact that the nuts on my column bracket were 10mm, maybe it changed..? [&:]
  #25
Old 11-24-2008, 07:50 PM
MadMikeZ28's Avatar
ORIGINAL: Jr. Mechanic
You are reffering to the nuts that hold the U shaped braket that has four bolts on it that holds the column up? If so you are going to have to check that again. The studs may very well be a 10mm but the nuts, or in some cases bolt heads are larger than a 10. Maybe you had to chase threads and used a 10mm tap
Ohh the four, five or so screws that hold the plate to the firewall are 10mm headed.
  #26
Old 11-24-2008, 07:52 PM
August 2009 ROTM
No, I remember it very well, two 10mm nuts holding my column up.
  #27
Old 11-24-2008, 07:54 PM
MadMikeZ28's Avatar
I want a pic!
tattoo400
08-01-2012 09:24 PM
69 Conv
08-19-2010 10:29 PM
Slick6
04-01-2008 10:46 AM
dustinb
10-01-2007 06:58 PM
Quick Reply: Head light switch broke - FIX??!?!?!?!
