hatch pulldown assembly
Old Nov 1, 2007 | 11:26 PM
oleblue88's Avatar
Default hatch pulldown assembly
i can get the hatch to latch but the pulldown motor doesnt work.. I know someone out there has had the same problem.please help[]
Old Nov 2, 2007 | 12:12 AM
MadMikeZ28's Avatar
Default RE: hatch pulldown assembly
Yes others have had problems. This subject has come up many times. If you do a search you will find more discussions on it. There is you electric motor that could go bad and a switch that tells the motor to go up and down due to its position. Those are two places to start looking after you checked all the fuses. There is also a fuseable link but other things will not work (head lights I know for sure) if it is bad.
Old Nov 3, 2007 | 09:43 PM
cjsuret's Avatar
sweet ride, where did you get your front grill with the b owtie on iT???
bd92rs
Apr 24, 2009 07:50 AM
Graphite07
Apr 8, 2009 11:42 PM
1989fbody
Dec 28, 2008 12:48 AM
matthew9440
May 12, 2008 08:07 PM
ohiocopper12
May 11, 2007 01:34 AM
