hard to start problem
Old Mar 18, 2007 | 02:58 AM
Booger's Avatar
Default hard to start problem
ok i got a 92 v6 3.1 5spd i bought the car it started fine, then next time i tried to start it took like 10 min, it starts and dies immediatelyit does this like 10 time then if you give it gas it finally starts with a puff of smoke, it gets worse every time i try it, now it wont even idle,check engine light is NOT on also when it did run if you were at lower rpms and hit the gas it would sputter and almost stall. i tjust took off egr and it had two gaskets on it and they looked like they were not sealed right you can see where there was an exhaust leak on it.
also its been running really rich, heres a list of whats been done recently
Fuel filter
IAC sensor
compression test(all at 150psi)
Fuel pressure test(within specs)
ANY IDEAS WOULD BE GREAT
Old Mar 18, 2007 | 03:55 AM
350DREAMS's Avatar
Default RE: hard to start problem
sparks and wires. because of the idle stall when ut ouch the gas tells me sparks and wires. did it when if rst got mine. also make sure u take off the distributor cap and make sure theres no rust or currosion.
Old Mar 18, 2007 | 05:15 AM
Booger's Avatar
well just puled off cap and its time to replace its worn and some corrosion si ile replace im not convinced that thats the only problem so ant more ideas would be great,
Old Mar 18, 2007 | 02:12 PM
350DREAMS's Avatar
dude 90% chance thats the only problems sparks and wires and can be ur 'everything'
Old Mar 18, 2007 | 11:02 PM
causindrama021's Avatar
check the timing all together.
Tim C
70-81 V8 Tech
May 6, 2012 11:03 AM
Tommyboyink
Oct 20, 2011 12:11 PM
Mj3039
Feb 16, 2011 02:42 PM
kyphur
Mar 21, 2009 02:32 PM
Codeman
Jan 25, 2008 05:30 PM
