granding sound when trying to start
Old May 26, 2006 | 04:21 PM
stitch85's Avatar
Default granding sound when trying to start
when i go to start my 305 with a quadrajunk car i get a loud grinding sound and smoke comes out my carb...could this be my starter or did i jam my pistons????
Old May 26, 2006 | 06:59 PM
Default RE: granding sound when trying to start
Does the engine turn over when you try to start??
Old May 26, 2006 | 09:29 PM
stitch85's Avatar
i cant tell over the grinding noise
Old May 26, 2006 | 10:03 PM
Have some one look while you crank. But I suspect the engine may me seized.
Old May 27, 2006 | 01:05 AM
v8chvyguy's Avatar
pull the starter and check the bendix and the flywheel i bet the teeth are chewed up. some of those starters have to be shimed. you may think it's a bad starter or batt. when all you need is a $2 shim kit. After 15 years of working on SB Chevys. I've seen a thing or three, including those Quadrajunks, as you call them, flat outrun better cars. don't be so quick to judge the Q jet I've got two and the one on my '79 Z28 has never been touched. the Q jet on my truck, that replaced the Holley, has been there for 5yrs. I installed it, set the idle speed and hav'nt touched it since. and they both pass the smog test first time every time.
sngehl01
Mar 7, 2012 11:44 AM
swalsh
67-69 V8 Tech
Feb 22, 2012 09:34 AM
maro1980
Aug 7, 2007 01:46 AM
stitch85
82-92 V8 Tech
May 26, 2006 10:02 PM
