Fuel pump change
RE: Fuel pump change
ORIGINAL: Gordon24Camaro
how do you loosen and remove the ring around the sending unit, thats were I had my troubles?
[/align]
[/align]
ORIGINAL: cjsuret
Is it possible to buy a feul pump that only pushes 7-8 psi?
There is a tab on the ring around the sending unit. You will need a large screwdriver to push the tab until it unlocks and then it will pop right off the sending unit. A little oil sprayed on the sending unit will help.
I have one, and I am getting mixed opinions on where to put it. One guy tells me to put it after the carb. He says that by putting it there, I wont restrict the flow to the carb ( heavy accelerations). I also have been told to put it before the carb. My prob is I am converting a 305 TBI to a 350 with a Holly 750 DP. I have two lines coming into the engine compartment. I know which is which. What I don't know is who to believe. If I put it before, that will solve my problems. If I have to put it after in order to not lose any power I cant seem to figure out where the return line comes out of the carb. This may be a no brainer, but I am amature when it comes to fuel systems. I also have my own thred titled 305 to 350 where I am encountering another problem if you wouldn't mind taking a look.
Put the regulator before the carb. How do you figure you are going to loose when a mechanical pump gives about 7 psi and it is before the carb. My brother has one line and a regulator before on his 59 Chevuy p/u and he has no loss of power. The mechanical fuel pump has a return line that goes back to the tank. There is no return on your carb.
ORIGINAL: cjsuret
johnson3034
05-25-2007 09:35 PM
