fuel pump
Old Apr 22, 2007 | 11:44 PM
hillangel's Avatar
Default fuel pump
I have a 92 camaro that was wrecked on the front end....we could get it started by putting gas under the hood...but it wont stay cranked. So we changed the fuel pump and it dosent even kick on. Its brand new. If anyone has any ideas please let us know. We have got 2 92 camaros that are doing the same thing. Both have been wrecked in the front end. By the way...already have checked all the fuses...installed a inline fuel pump on one of the cars and it still wont stay cranked.
Old Apr 23, 2007 | 03:25 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: fuel pump
What kind of damage? What was done to the motor?Anything knocked loose? Is your timing set correctly, or at least close?
Old Apr 23, 2007 | 06:33 PM
Goodfella's Avatar
fuse perhaps?
Old Apr 23, 2007 | 08:50 PM
Some cars have sensors that turn off the fuel pump in case of a crash, but I am not sure about 3rd gen Camaros.
Old Apr 23, 2007 | 09:12 PM
MadMikeZ28's Avatar
Have you check if the front end damage cut a ground wire? Have you tried to crank the engoine over until it gets oil pressure to see if the pump kicks on then?
Old Apr 23, 2007 | 11:58 PM
hillangel's Avatar
hey..my husband said the front end passenger side run under a diesal..busted the headlight and fender and the other car went into a ditch. We have 2 camaros. Both are doing the same. He said he hasnt checked a ground wire.
Old Apr 24, 2007 | 09:15 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Check everything, lines...hoses...all the stuff, ensure it is all there and atached. You might need to take it to a shop who can look at it. Whithout seeing it and doing diagnostic checks its hard to tell whats wrong over the internet.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
