fuel pressure gauge questions.
Old Feb 12, 2009 | 10:46 AM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
Default fuel pressure gauge questions.
I have recently installed a fuel pressure gauge on my car bc I was concerned I wasnt getting enough fuel. I have recently realized that I dont know how it is suppose to read. when the engine is at idle the needle bounces between 4 and 5 psi. when it is under load it reads a steady 5 to 6 psi. Is this right and would getting an aftermarket fuel pump give me any hp or performance gains?
Old Feb 12, 2009 | 10:52 AM
Saint_Ali's Avatar
that doesnt sound right....idle should be around 50 psi and at WOT it should be near 60 if not more than that
Old Feb 12, 2009 | 11:42 AM
You're converted over to carb. aren't you? Then that's working just fine. Seeing a bounce in the needle is normal since the mechanical pump is cam driven, and not a constant steady-flow pump like an electric. And no, an aftermarket pump won't give you any h.p. or perf. gains. One might give you more reliability, but yours is working fine.
Old Feb 12, 2009 | 11:55 AM
Yeah, my car is converted to a carb setup. Sorry forgot to mention that Alih. Thanks 69 I wasnt sure if the bouncing was normal and now I can focus my fuel pump money elsewhere.
also I noticed you specifically said me, just curious what setup would benefit and why wouldnt I? not doubting your word, just wanting to learn a little.
Old Feb 12, 2009 | 12:48 PM
bobarian91's Avatar
BackseatBob
Yeah, getting a higher pressure fuel pump wont help anything... my car was at 10psi at 2500rpm and it was bogging down my motor and making it stall. You're doin good.
Old Feb 12, 2009 | 03:57 PM
Jr. Mechanic's Avatar
August 2009 ROTM
More PSI is not the goal. Constant PSI is. Lets use 69's engine for an example. Say you were to put your fuel pump on his engine. It would run fine at idle, but as soon as you lay into it, those two carbs would be demanding much more fuel than that pump could keep up with, dropping the fuel pressure off. Only time more fuel pressure gives you more power is in fuel injection, and only to a certain extent. The higher pressures allow the injectors to spray a finer mist, allowing easier combustion. As long as you can keep at least a constant 2-3 PSI, your car will run fine. Anything more than 8 or so you start getting problems.
Tipsy
Mar 23, 2014 07:32 PM
numskull223
Oct 10, 2011 01:02 PM
GeorgeLeonard
Aug 18, 2008 01:36 PM
bigblockhemi
Mar 19, 2007 05:04 PM
bigblockhemi
Mar 2, 2007 12:01 PM
