fuel lines
Old Jun 14, 2007 | 03:12 PM
350rs's Avatar
March 2008 ROTM
Default fuel lines
on the TBI. which line is the supply? and which is the return? when i look on the back, there are two lines. I need to check the pressure and need to know which line is which
Old Jun 14, 2007 | 08:47 PM
MadMikeZ28's Avatar
Default RE: fuel lines
The inlet is the one on the drivers side. Don't lose your O rings as you take it apart
Oh and you check pressure on the return line
Old Jun 15, 2007 | 03:45 PM
350rs's Avatar
March 2008 ROTM
we did a few different pressure checks yesterday. All is well with pressure, so it has to be my regulator, im gona try and rebuild it this weekend. wish me luck..
btw, i discovered, your car runs like CRAP with the MAP vaccum off... lol oops but it does KINDA sound like it has one hell of a lopey cam in it.
Old Jun 15, 2007 | 06:24 PM
MadMikeZ28's Avatar
Well when you test on the return line it is testing after the regulator. When you yesyed the pressure did you do it with the car running? When you rapp the throttle (and the vacuum drops) did the pressure jump hugher? After you turn the key off and the pump stops running how fast did pressure bleed down?
Old Jun 15, 2007 | 08:31 PM
350rs's Avatar
March 2008 ROTM
i tested it running and off. No extreme jumping on vaccume lines or anything. Everything was great, never did test the return lines though... but i mean, from being able to SEE the fuel being practically dumped in to the TBI with a garden hose, im thinking it HAS to be the regulator...
juice+
Jun 9, 2012 10:51 PM
Dcapper81
Mar 4, 2012 02:35 PM
mrfreez
Jan 21, 2011 11:58 PM
Amy Z28
Sep 5, 2009 11:30 PM
sorrell45
70-81 V8 Tech
Jan 20, 2009 10:55 AM
