frame problem
If there is room a steel plate can be welded over the crack, has to be done carefully so as not to weaken the frame at the weld point. This is a weak point on the frame due to mounting holes and stress caused by the steering mechanism.
If there is room a steel plate can be welded over the crack, has to be done carefully so as not to weaken the frame at the weld point. This is a weak point on the frame due to mounting holes and stress caused by the steering mechanism. A bad steering box won' cause the problem, but continuos pounding year after year will.
