Sub Frame
Old May 26, 2007 | 10:25 AM
nuttyprofessor's Avatar
Default Sub Frame
I want to buy a new subframe for my 81 camaro....saw a Chris Alston but only for the 68-72. Anyone know where I can find a new aftermarket subframe?? I was planning on finishing my restoration this year and the new subframe, rear four link setup and subframe connectors are all I need to install before I paint.
Old May 26, 2007 | 10:43 AM
74454bb's Avatar
May 2007 ROTM
Default RE: Sub Frame
This is all I could find for a 2nd gen subframe. http://www.jegs.com/webapp/wcs/store...p;x=11&y=8
Old May 26, 2007 | 09:02 PM
NMcamaro's Avatar
do you want the whole front assembly? rack and pinion steering or stock? there are plenty of places out there that can fabricate a subframe for you. this is an extreme example but you should get the idea.
http://www.jimmeyerracing.com/cm1.html
here's another one thats a little cheaper.
http://www.martzchassis.net/page1.htm
Old May 27, 2007 | 05:45 AM
Blade's Avatar
June 2007 ROTM
try checkeredracing.com that is where i got mine.
Old May 27, 2007 | 09:40 AM
74454bb's Avatar
May 2007 ROTM
oops he ment front....Well if you have the cash for the front do the rear to....it helps alot.
Old May 27, 2007 | 10:47 AM
Blade's Avatar
June 2007 ROTM
lol subframe is the front. u always trying to get someone to buy them frames.
Old May 27, 2007 | 10:53 AM
74454bb's Avatar
May 2007 ROTM
I know but they are awsome..............if they are put in right.
Old May 28, 2007 | 06:58 PM
Yeah I am looking for the front section with the rack and pinion and all. Wanna be able to eventually put in a LS1 with the T56. I plan on doing the rear frame section as well by putting in one of the bolt in four link systems.
pimnmike
Jan 20, 2011 08:41 PM
Brandon96z28
Nov 12, 2010 08:15 PM
cadfleet
Mar 7, 2010 08:38 PM
benz660r
Sep 18, 2006 05:50 AM
hugo_a2003
Sep 1, 2006 06:43 PM
