Foul Cabin Odor
Old Mar 26, 2007 | 10:32 PM
asdfghjkllkjhgfdsa's Avatar
Default Foul Cabin Odor
In my Camaro, it smells like Gasoline. All the time. I havent spilled anything or drilled anything into the floor.
Where could this be comming from?
Old Mar 26, 2007 | 11:46 PM
rs305's Avatar
Default RE: Foul Cabin Odor
I have that same problem. When i fill the tank, gas pours out of the tank because the seal is no good. I dont know how to fix that though. if anyone has any idea, let me know.
Old Mar 27, 2007 | 12:02 AM
MadMikeZ28's Avatar
A foul cabin odor could just be your upper lip you are smelling.
I am sorry. I had to say it.
Can you smell it from under the hood? No fuel lines or any other one go through the car.
As for gas pouring out of the tank because of a seal being bad is odd since the tanks filler neck is part of the tank and the only seal is in the sending unit. So you must happen when its full. You could check your lines. What you can see of them anyway.
Old Mar 27, 2007 | 05:47 PM
84VarinZ28's Avatar
sounds like u might have a problem with your evaporative emissions system. check the vapor canister and make sure it is sealed. if any lines going to/from it look old and cracked then gas vapors will escape from it and could end up in the passenger compartment. also the system should purge itself anytime u open the throttle.
Nmead91
LS Series Tech
13
Jul 10, 2011 05:44 PM
skylinrcr01
Oct 28, 2010 11:38 PM
fluger77
Sep 7, 2007 08:17 PM
ryan88z
Mar 27, 2007 07:53 PM
motor tec
Oct 23, 2006 01:32 PM
