exhaust cut outs ?
exhaust cut outs ?
i have a lt1 built for my car and have a exhaust system in my car now but i want to put some electronic cutouts on it but with it being fuel injected wont that cause alot of sensors to fail i have heard the o2 sensors can fry because of this so should i look into it or just for get about it
It would have to go after the cat to be 100% sure to eliminate problems. I've thought about putting them on mine once I get all the exhaust work done, but I have true duels with two cats, and no sensors to worry about. Honestly, they flat out aren't worth it unless that car is garaged and never gets driven in the rain or they will fail to open in no time .
what year lt1 is it? if its a 96-97, you will throw a code for cat efficiency if you use a cut out before the cat. if its 92-95, you can run a cutout before the cat, but no closer than 8 inches from the o2 sensor. anything closer and it will affect the readings
its a 93 block from another z-28 but has been completely forged and is running a 95 computer with a custom pcm chip
