engine stall
Old Jul 26, 2006 | 08:33 PM
86roc's Avatar
Default engine stall
1986 camaro 305 tpi it stall form idle sometime it has it and sometime it don't does it hot or cold more hot than cold has new tps ,iac ,spark plugs , wire's ,fuel filter ,and rotor have put 4 mass air flow 3 used 1 new fuel pressure is @ 44 psi when key is on 38 psi @ idle die on me today and had to wait 5 mins. for it to re start
Old Jul 26, 2006 | 10:06 PM
blackz87's Avatar
Default RE: engine stall
Vacumum leak could be the problem.
Old Jul 27, 2006 | 11:20 AM
86PREDATOR's Avatar
Does it attempt to turn over? or is it completely dead for 5 mins. Also does it stumble., or anything?
Old Aug 2, 2006 | 09:27 PM
86roc's Avatar
well took car to the shop and they are saying that the injector might be bad ohm out at 16.5 to 16.8 and alldata say 16.35 max
Cerridius
Feb 17, 2012 08:14 PM
Camaro78'
Sep 5, 2011 05:02 PM
Chevy_Muscle
Aug 14, 2009 02:46 PM
duke15
Nov 18, 2008 04:05 PM
nj93zkid
Feb 25, 2007 04:22 PM
